JKEdmo Posted May 30, 2024 Share Posted May 30, 2024 Using construction lines for first time in Chief and liking them. I have them set to display on all floors. So far so good. But, I'd like to dimension them. I don't suppose there is a setting that allows dimensions to display on all floors also? Thanks, Jim Link to comment Share on other sites More sharing options...
SNestor Posted May 30, 2024 Share Posted May 30, 2024 You could place those specific dimensions on a unique layer and the use a custom reference layer set to show them on other floors. 1 Link to comment Share on other sites More sharing options...
JKEdmo Posted May 30, 2024 Author Share Posted May 30, 2024 1 hour ago, SNestor said: You could place those specific dimensions on a unique layer and the use a custom reference layer set to show them on other floors. Steve, I tried what you suggested, but display of dimensions still is affected by floor level. (I think I understand the concept -- draw everything I need for gridlines and their associated dimensions and then bring it into other floors as a Reference Display?) BASSETT 2 - PROPOSED.zip Link to comment Share on other sites More sharing options...
SNestor Posted May 31, 2024 Share Posted May 31, 2024 Jim - Create a dimension default that you will use to dimension only the construction lines. These dimensions should be on their own layer. Then...create a REF SET (which you had already done) and the only layer on in this set should be the layer you created for these dimensions. Examine the attached plan. If you go to the 2nd floor...you will see the referenced dimensions. BASSETT 2 - PROPOSED - Ref Dim Fix.zip Link to comment Share on other sites More sharing options...
JKEdmo Posted May 31, 2024 Author Share Posted May 31, 2024 14 minutes ago, SNestor said: Jim - Create a dimension default that you will use to dimension only the construction lines. These dimensions should be on their own layer. Then...create a REF SET (which you had already done) and the only layer on in this set should be the layer you created for these dimensions. Examine the attached plan. If you go to the 2nd floor...you will see the referenced dimensions. BASSETT 2 - PROPOSED - Ref Dim Fix.zip 10.5 MB · 0 downloads Thank you Steve for taking time out to look at this. I'll have to study this further in the morning. Jim Link to comment Share on other sites More sharing options...
