GeneDavis Posted May 27 Share Posted May 27 And by that I mean render it in 2D elevations and 3D camera views. I did a search and could find no "hog" anything, but maybe I am not a good searcher. I seem to recall it being discussed here. For those of you that are not pig farmers, hog panel is a hot design thing in deck railings. Heavy gage wire 4x4 inch spacings, panels sold in 4'x8' size so easy to fit in yer pickup. Sold galvanized and with black powdercoat finish. Link to comment Share on other sites More sharing options...
JKEdmo Posted May 27 Share Posted May 27 5 minutes ago, GeneDavis said: Heavy gage wire 4x4 inch spacings Gene, Like this? The panel type is called "Cross Hatch." I found it under fences and railings / ironwork in the Core Architectural catalog. Oink! 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted May 27 Author Share Posted May 27 Thanks @JKEdmo, but I cannot get there. I found the library item but it seems (for me) it is not a material but a millwork-type item. I could not get it as a material selection for a panel railing, but can get something when I go after it in the balusters dialog. See the pic. Please describe the step by step to get what you showed. Thanks. Link to comment Share on other sites More sharing options...
GeneDavis Posted May 27 Author Share Posted May 27 Got it! Thanks. Link to comment Share on other sites More sharing options...
JKEdmo Posted May 27 Share Posted May 27 44 minutes ago, GeneDavis said: but I cannot get there Gene, I've attached the PLAN file for you to look at. It was a panel item from the library. JimHOG RAIL.plan Link to comment Share on other sites More sharing options...
