buzzsaw204 Posted May 20, 2024 Share Posted May 20, 2024 Hi, i thought i have done this step/task many time before of importing a Wall Type from the Library. I thought you could always just drag and drop the Wall Type it into your plan? That doesn't seem to work anymore, or am I forgetting some other step it another way to do it?? Link to comment Share on other sites More sharing options...
TeaTime Posted May 20, 2024 Share Posted May 20, 2024 You never drag items from the library. I'm pretty sure you just select it in the library and Draw a wall out as you normally would. Link to comment Share on other sites More sharing options...
buzzsaw204 Posted May 20, 2024 Author Share Posted May 20, 2024 6 minutes ago, TeaTime said: You never drag items from the library. I'm pretty sure you just select it in the library and Draw a wall out as you normally would. it would have to exist in the Plan for you to use it. if it's not....then you would need to Create/make a new OR import it, so that you have it, to able to use it. Link to comment Share on other sites More sharing options...
Solution TeaTime Posted May 20, 2024 Solution Share Posted May 20, 2024 Not if it's in the Library Browser, that's the whole point of saving Line Styles and Walls and Moldings, etc etc, is that they don't need to exist in the plan. you just Select that Library object and then click and drag on the plan to create that object. Once you do that, that Wall Type exists as part of that plan. I just tested it, made a Siding-6 with two layers of siding, add to Library, open New Plan, grabbed it in my library and drew out a wall using that new definition. There's no Import process, you just use it. 1 Link to comment Share on other sites More sharing options...
buzzsaw204 Posted May 21, 2024 Author Share Posted May 21, 2024 20 minutes ago, TeaTime said: ....you just use it. thank you! 1 Link to comment Share on other sites More sharing options...
