BryanXG Posted May 20, 2024 Share Posted May 20, 2024 After upgrading to x15 and importing all my existing x14 Library's I noted 4 library's where listed with no content (Beams, Wall Types, Kohler®, Wilsonart®). On checking it says "The Catalog Could Not Be Found On The Server". In the Library browsers it shows the items as being "online" and asks to download... after the download and install I get a message "The Library Import has completed successfully. No items were successfully imported. Duplicates, and items from incomparable versions will not be imported." If I go directly to the x15 catalog online and download it, I still get the same result. Suggestions? Link to comment Share on other sites More sharing options...
TeaTime Posted May 20, 2024 Share Posted May 20, 2024 Generally speaking if you search the error your getting on their webpage, you'll find there's likely an article with info on it and steps to fix https://www.chiefarchitect.com/search/?default_tab=all&q=The+Catalog+Could+Not+Be+Found+On+The+Server 2 Link to comment Share on other sites More sharing options...
BryanXG Posted May 21, 2024 Author Share Posted May 21, 2024 A search is my first move ("search is your friend"), but sometimes the results are anything but a match, even if a match exists. Your link provided just what I needed... thank you. Link to comment Share on other sites More sharing options...
