Gdorough11 Posted May 17, 2024 Share Posted May 17, 2024 I am trying to build a multi pitch roof system with an included loft floor system and cannot get past this error message of roof planes adjustment sufficient to eliminate upper plane. Anyone run into this before?? Thank you! Link to comment Share on other sites More sharing options...
Chopsaw Posted May 17, 2024 Share Posted May 17, 2024 Hard to say for sure. Perhaps you have the DBX format set to feet and you are making entries in inches that are being interpreted as feet. Maybe a little more information on exactly what you were doing to cause the error message to come up since it sounds like it has happened multiple times. You can always post your plan file and perhaps one of the experts will take a look for you if they know exactly what you are attempting to achieve. Link to comment Share on other sites More sharing options...
para-CAD Posted June 2, 2024 Share Posted June 2, 2024 My suggestion to the OP is, if you are paid up on your SSA, then call tech-support at chief and share your plan with them. They may be able to give you some pointers on how to accomplish what you’re trying to do. Link to comment Share on other sites More sharing options...
