crpd12 Posted May 9, 2024 Share Posted May 9, 2024 I need to build a 57" wide base cab that has 3 vertical sections. I cannot figure a way to do that. The default in the edit box split the cabinet in 2 equal vertical sections with no way that I can see to specify distances. What am I missing? Is there a way to do that? Thanks Link to comment Share on other sites More sharing options...
TeaTime Posted May 9, 2024 Share Posted May 9, 2024 Split it into two equal sizes. Select one of the new vertical layouts and split it into two equal parts (giving a 25/25/50 layout) Select the horizontal layout that all these are contained in (likely #2) and hit Equalize. Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 9, 2024 Share Posted May 9, 2024 "Layout" Indicates a parent section that allows you to specify assignments for the child designations. Link to comment Share on other sites More sharing options...
