cbucks Posted May 8, 2024 Share Posted May 8, 2024 I am using a program called swmaps, it exports a GPX file but chief doe not read the file I guess it is track and I need to convert to waypoints. I tried using this site to convert to waypoints which it does and chief imports however somehow during the process the elevations get messed up. When I open the raw files it appears the data is in meters and not feet which I believe is the problem https://www.alltrails.com/converter Anyone know of any good tools to convert GPX files from tracks in meters to a GPX with waypoints in feet? Link to comment Share on other sites More sharing options...
Chopsaw Posted May 8, 2024 Share Posted May 8, 2024 Any luck importing into a metric template ? Might be worth a try. Link to comment Share on other sites More sharing options...
