KristjanM Posted May 4, 2024 Share Posted May 4, 2024 Two part question - 1) For an object (a closed polyline for example), the object properties gives several items which are classified as measurements. These items can produce a totals row in a schedule. In my case, my area displayed would be in sq. ft. I also need sq metres which I can get by doing some kind of conversion in a custom field or using a object information field. All is good as I have the two numbers displayed in the schedule. However, the sq m field doesn't total even if I convert it to a float. It seems that only measurement fields will total and there is no way to define a custom field as a number. Correct or not? Is there a way to get a total from custom field? 2) I have total displayed in a schedule. Is there any way to grab this number for use as a variable? Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 4, 2024 Share Posted May 4, 2024 1 hour ago, KristjanM said: 2) I have total displayed in a schedule. Is there any way to grab this number for use as a variable? No. I've asked for it Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 4, 2024 Share Posted May 4, 2024 1 hour ago, KristjanM said: It seems that only measurement fields will total and there is no way to define a custom field as a number. Correct or not? correct. One can hope it comes in X16 Link to comment Share on other sites More sharing options...
KristjanM Posted May 4, 2024 Author Share Posted May 4, 2024 Thanks for your comments. Kind of what I thought but you never know. Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 5, 2024 Share Posted May 5, 2024 6 hours ago, KristjanM said: Thanks for your comments. Kind of what I thought but you never know. you can produce totals with custom macros and global variables.. Link to comment Share on other sites More sharing options...
