DefinedDesign Posted April 27, 2024 Share Posted April 27, 2024 Need to change the 2nd floor structure to 8 1/4” and I need the entire floor structure to lower so the finished ceiling height increases on the 2nd floor and the 1st floor finished ceiling height remains the same; however, when I edit the Floor Structure - it always increase the 1st floor finished ceiling height. What is the secret sauce? Link to comment Share on other sites More sharing options...
Solution GeneDavis Posted April 27, 2024 Solution Share Posted April 27, 2024 Always edit floor heights doing top floor first and go down. You'll get it once you've done it. Once you've changed the floor structure in all the upstairs rooms (and you've used Match Properties to do so), go to floor 1 and work the ceiling heights using the same Match Properties tool. 1 Link to comment Share on other sites More sharing options...
DefinedDesign Posted April 27, 2024 Author Share Posted April 27, 2024 @GeneDavis Thank you That Worked! Link to comment Share on other sites More sharing options...
