HOW TO DO A REVEAL BETWEEN BASE BOART AND THE SHEET ROCK?
Sandor09
Good morning from Portugal to all!
I am doing my first steps in the Chief Architect and I am trying to learn as much as I can.
Now I am facing with the following doubt:
HOW TO DO A REVEAL BETWEEN BASE BOARD AND THE SHEET ROCK?
Please see my attached image for better understanding.
I will also need for ceiling but the concept should be the same.
Thank you so much in advance!
The easiest way that I have found is to use room moldings. Easy to apply to a whole floor, a room and/or eliminate on walls as desired with CA's room molding control. I used the air gap material at first but prefer the look of just black color. Use moldings set 1/32 to 1/16 proud to inside of wall face to avoid 3D "Z-fighting".
Thank you so much dear Charles,
I will try your option tomorrow because I spent my entire day trying to find the solution :) but with no success.
And the same type of reveal around the ceiling? Is it possible?
thanks once again!
Good morning Charles,
Refering your help from yesterday... I have all my definitions like your samples and I cant see any reveal in the 3D.
Please see the images below.
Thanks!
Post your plan! Otherwise we are all guessing.
Guesses:
  1. You did not apply that molding to the wall of your 3D view.
  2. You did not use black material for the reveal molding and white for the base molding.
Best,
Charles
