Renerabbitt Posted April 23, 2024 Share Posted April 23, 2024 do we not have this? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 23, 2024 Share Posted April 23, 2024 No. I just enter the label and use that. ie: 42" Tall Glass Railing Link to comment Share on other sites More sharing options...
Renerabbitt Posted April 24, 2024 Author Share Posted April 24, 2024 5 hours ago, Joe_Carrick said: No. I just enter the label and use that. ie: 42" Tall Glass Railing welp this only works with solid walls since its using drywall for the calc but here ya go: # Copyright Rabbitt Design 2024 # This macro is in your Room Label but can also be used in a polyline or rich text box ########################################################################################## # Rabbitt Design assumes no liability for the accuracy of this macro calculation or # any consequences arising from the use of this script. Users are responsible for verifying # the appropriateness of the settings within the label options and ensuring the script functions as intended # in their specific use case. ########################################################################################## referenced ? obj = referenced : obj = owner ########################################################################################## #FORMATTER formatter = NumberFormatter.new formatter.use_fractions = true formatter.denominator = 4 formatter.show_trailing_zeros = true formatter.unit = '"' # Set units to inches formatter ########################################################################################## #SCRIPT is_railing_wall = obj.respond_to?(:is_railing) && obj.is_railing if is_railing_wall && obj.respond_to?(:upper_layers) && obj.respond_to?(:length) layer_with_greatest_thickness = obj.upper_layers.max_by { |layer| layer.thickness } if layer_with_greatest_thickness area_sq_in = layer_with_greatest_thickness.area.convert_to(:"sq in") railing_height_raw = area_sq_in / obj.length.to_f # Apply formatter only to the final railing height result railing_height = formatter.apply(railing_height_raw.round)+"w/Rail Cap" else railing_height = "No valid layer found" end end Link to comment Share on other sites More sharing options...
