agriffiths Posted April 17, 2024 Share Posted April 17, 2024 Hi Everyone! I am hoping to get your help here! I have a weird roof plane issue and can't seem to make things connect. I've played around with the auto build, the manual function etc. and adjusted each value separately, but for some reason, the corners of this little roof will not connect. Everything else is working fine - the lines against the house are great, the pitch is great, but this is off. Any help is greatly appreciated!! Link to comment Share on other sites More sharing options...
Renerabbitt Posted April 17, 2024 Share Posted April 17, 2024 20 minutes ago, agriffiths said: appreciated best if you post your plan file. The return roof plane has been moved so the baseline is not snapped to your main wall layer. There are some other things a bit off as well possibly. try posting the .plan Link to comment Share on other sites More sharing options...
agriffiths Posted April 17, 2024 Author Share Posted April 17, 2024 ChiefSupport.planHere you go!! ChiefSupport.plan Link to comment Share on other sites More sharing options...
CharlesVolz Posted April 17, 2024 Share Posted April 17, 2024 Ariane, Here you go. Plan: https://drive.google.com/file/d/1128UHU2h8zHtCeqXsTDZGzCCT3a1A8Iw/view?usp=sharing Video: https://drive.google.com/file/d/1YBRvWFD_XWhCIS3UxGuZGEYmCh07bMxg/view?usp=sharing Link to comment Share on other sites More sharing options...
agriffiths Posted April 17, 2024 Author Share Posted April 17, 2024 @CharlesVolzThank you so much!!!! I will make some changes to my program tools and replicate your instructions!! I am just replicating an already built house for a proposal so I'm not terribly worried about tech specs/regulations, but the more you know right? Thanks so much!!! Curious though, what the diff between a roof and a shed roof?? Link to comment Share on other sites More sharing options...
CharlesVolz Posted April 17, 2024 Share Posted April 17, 2024 Hip roof: Shed roof: 1 Link to comment Share on other sites More sharing options...
agriffiths Posted April 17, 2024 Author Share Posted April 17, 2024 Ah!! I didn't connect the two, I'm in my own world today. Too many weird things going wrong, thought it was something fancy Thank you again!! Link to comment Share on other sites More sharing options...
