DIYJon Posted April 4, 2024 Share Posted April 4, 2024 I've used the Fence feature to build a wrought iron gate whereby the Balusters are the 1/2" uprights between both of the 1 1/2" posts and 1 1/2 top and bottom rails. It looks great. The only problem is that I can't figure out how to insert synthetic 5" wide slats between the Balusters. If I create a 3D shape, it's constrained by the fence planes and can't slip between. If I edit the fence and change Balusters to Panels, I get alternating wood panels which resemble what I'm looking for, but that removes the wrought iron Balusters, naturally. Is is possible I may have to completely model the entire gate as a 3D object rather than building a fence between the block wall pilasters? I suppose modeling it would also allow me to add the doorknob insert on the gate as well as the flat-iron cross beams which the boards attach to... Thoughts? Link to comment Share on other sites More sharing options...
DBCooper Posted April 5, 2024 Share Posted April 5, 2024 It would help to show a picture of what you are trying to model. You might be able to create a symbol that has both the balusters plus the wood slat and use that as either your baluster or panel symbol in the rail. Link to comment Share on other sites More sharing options...
