kwhitt Posted April 4, 2024 Share Posted April 4, 2024 I’ve got a situation where an irregularly-shaped chimney pad will be forming a section of a room’s wall – first attachment. Obviously, this custom pad cannot act as a true wall which I need to be able to create the room definition. What are you doing in instances like these? Using invisible walls to fill in those areas to define the room? This house also has several walls that come to sharp points – second image. Is there a way to deform walls in Chief to take on this shape? If not, I can use poly-solids to get it to look right in 3D but what do I do in plan view to represent this shape? Thanks, Kevin Link to comment Share on other sites More sharing options...
kwhitt Posted April 5, 2024 Author Share Posted April 5, 2024 No one has any input on this? Thanks. Link to comment Share on other sites More sharing options...
robdyck Posted April 5, 2024 Share Posted April 5, 2024 1 Link to comment Share on other sites More sharing options...
kwhitt Posted April 5, 2024 Author Share Posted April 5, 2024 21 minutes ago, robdyck said: Thanks Rob. Very cool. I'm assuming that is an invisible wall? Is my idea of using invisible walls for the first question, the only way? Link to comment Share on other sites More sharing options...
robdyck Posted April 5, 2024 Share Posted April 5, 2024 Yes, I used an invisible wall (1/2" thick, drywall material) Umm, no, invisible walls wouldn't be the only way, but it might be the best option. There could be more to the story that I can't tell from the picture, you know? From what I can tell, I'd stick with using the same wall type for the concrete foundation and make it invisible. That should also give you decent wall connection control. 1 Link to comment Share on other sites More sharing options...
kwhitt Posted April 6, 2024 Author Share Posted April 6, 2024 17 hours ago, robdyck said: Yes, I used an invisible wall (1/2" thick, drywall material) Umm, no, invisible walls wouldn't be the only way, but it might be the best option. There could be more to the story that I can't tell from the picture, you know? From what I can tell, I'd stick with using the same wall type for the concrete foundation and make it invisible. That should also give you decent wall connection control. Thanks again, Rob. 1 Link to comment Share on other sites More sharing options...
