SteveO Posted March 21, 2024 Share Posted March 21, 2024 I currently have siding on the exterior of my house design. I downloaded the Sherwin-Williams catalog into the Manufacturer Catalogs folder in the Library Browser so I can see what some of the different S-W colors look like on the house exterior. I've been using either the Adjust Material Definition or the Material Eyedropper tools to get the different S-W colors on the exterior of the house, BUT when I do this the exterior "siding look" changes to a "flat surface" look. So, I'm looking for a way to try these different S-W colors - from the downloaded S-W Catalog in the Library Browser - WITHOUT changing the house exterior siding to a flat surface. Don't know if this matters, but I'm using an older version - Home Designer Suite 2016. Any help would be much appreciated. Link to comment Share on other sites More sharing options...
RL-inc Posted March 21, 2024 Share Posted March 21, 2024 Not sure how it works in HD - I believe they have their own forum- but in CA there is an option to blend texture with materials which should take care of it. 1 Link to comment Share on other sites More sharing options...
Solution TeaTime Posted March 21, 2024 Solution Share Posted March 21, 2024 Yeah definitely want to ask the HomeTalk forums. It appears HD does have the same blend function https://www.homedesignersoftware.com/support/article/KB-00131/using-the-blend-colors-with-materials-tool.html but I don't know if it had it in 2016. I suspect you should still be able to use the Adjust Material tool though. On the Texture panel there should be an option to blend the color there. The color chooser allows you to eyedropper a color from anywhere on your screen, so if you open your library browser to that material beforehand you should be able to pick it up from there. 1 Link to comment Share on other sites More sharing options...
SteveO Posted March 22, 2024 Author Share Posted March 22, 2024 Thanks for the replies. Will try the suggestions tomorrow and let you know. Link to comment Share on other sites More sharing options...
SteveO Posted March 22, 2024 Author Share Posted March 22, 2024 Just opened the link from Tea Time and followed the directions, and it worked great. Much better look. Thanks again to all. Link to comment Share on other sites More sharing options...
