Dormer Window Help
CCI_alexandria
I am having trouble adding a dormer window to mirror the current one, just need it on the other side of the house. It will only allow the auto size, as soon as I extend it even an inch bigger it says "Cannot build walls for this dormer here because existing walls are in the way. It needs to be moved to another position." That said, there are no other walls in the way! I can't figure out what needs to move, be deleted or added. I need the same size on the top side, as the lower.383881327_Screenshot2024-03-20at2_36_17PM.thumb.png.c7c4bc8b626da9b625ddb3056d8dfaba.png
you could just explode your dormer and finish up the rest by manually moving your walls
