Trying to import a GPX file and getting error "the GPX file can not be read in by program"
cbucks
Yes, gpx is supported but maybe your format is newer than Chief can read?  Or maybe it doesn't have any way points?
Here is a tech article that might help:
https://www.chiefarchitect.com/support/article/KB-00719/importing-terrain-elevation-data-from-a-dwg-or-dxf-file.html
It has this info about gpx files:
GPS data in a .gpx file format can also be imported by selecting File> Import> Import GPS Data ImportGPS.png?1709065706.GPS data may include three types of points - Way, Track and Route. Chief Architect can only import a .gpx file if it includes one or more Way Points. If a *.gpx file is imported and it contains no Way Points, no data will be imported. Route Points contained in a .gpx file will not be recognized upon importing.
Thanks I didn't realize Chief will only recognize waypoints.  It looks like the gpx file exported as track points in SWMaps. Is there a way to convert my track points to way points since it appears Chief only supports waypoints?
https://aviyaantech.com/swmaps/index.html
