community Posted February 27, 2024 Share Posted February 27, 2024 How do I control the baseboard that shows in the 3d room interior view? Link to comment Share on other sites More sharing options...
Rich_Winsor Posted February 27, 2024 Share Posted February 27, 2024 To get you started select (highlight) the room you want to work on. Select 'open object" to go to the Room Specification DBX. Select 'Moldings' and uncheck the 'Use Floor Defaults' box. You now can use the controls to in the DBX to manipulate the base boards. If you click 'Replace' it will take you to the library where you can choose any style you wish. Hope this helps. Link to comment Share on other sites More sharing options...
community Posted February 27, 2024 Author Share Posted February 27, 2024 OK, thanks for that. What if I want to change the default base boards? Link to comment Share on other sites More sharing options...
MarkMc Posted February 27, 2024 Share Posted February 27, 2024 Default settings. Floors and rooms Link to comment Share on other sites More sharing options...
community Posted March 26, 2024 Author Share Posted March 26, 2024 I have changed the default base molding to the size that I want but this still doesn't show right profile in the perspective floor overview. Link to comment Share on other sites More sharing options...
Solution community Posted March 28, 2024 Author Solution Share Posted March 28, 2024 OK, I have found where to change this: it is in Floor levels, first floor. Link to comment Share on other sites More sharing options...
