JKEdmo Posted February 22, 2024 Share Posted February 22, 2024 Quick question -- Does Chief allow you to assign / paint properties from a wall railing to a stair railing? I have a railing wall defined and would like to quick-apply to my stair railing without having to go into the stair properties and adjusting the railing specs. Kind of think no, but I thought I'd ask. Thanks once again, Jim Link to comment Share on other sites More sharing options...
Solution TeaTime Posted February 22, 2024 Solution Share Posted February 22, 2024 Frustratingly, no. When you use the Object Eyedropper, hit the Select Properties to Paint button in the lower left to see all the things that can be picked up and applied onto other objects. Railing walls have the "is railing" setting but none of the newel or baluster settings that would be needed. Link to comment Share on other sites More sharing options...
JKEdmo Posted February 22, 2024 Author Share Posted February 22, 2024 On 2/22/2024 at 7:14 PM, TeaTime said: Frustratingly, no. Expand Awww shucks! On 2/22/2024 at 7:14 PM, TeaTime said: hit the Select Properties to Paint button Expand Thanks! this was new to me. Jim Link to comment Share on other sites More sharing options...
