RL-inc Posted February 15, 2024 Share Posted February 15, 2024 Good day- and long time no post- I am trying to create a simple drawing set for a small exterior roof addition to an existing home. Based on the ARC requirements, a plan view and a couple elevations are really all I need. The owner provided the basic PDF files of the elevations pages, and I have been able to create the 2 views I need- side and straight on. The issue is when I send to Layout, the PDF background is showing through the new components - which is not the case in the elevation view in the plan file. Any comments are appreciated. Here is plan file view- and here is the way it appears in Layout Link to comment Share on other sites More sharing options...
SHCanada2 Posted February 15, 2024 Share Posted February 15, 2024 maybe I'm not good at the spot the difference game, but the only difference I see is colour vs black and white Link to comment Share on other sites More sharing options...
RL-inc Posted February 16, 2024 Author Share Posted February 16, 2024 If you look at the Layout image you can see that the roof just to the right of the chimney is showing behind the new roof plane- The dim out by the post as well. Link to comment Share on other sites More sharing options...
SHCanada2 Posted February 16, 2024 Share Posted February 16, 2024 I'm not sure I understand. Are you saying the dimension number itself is in the PDF, but not the dimension line? It looks to me that perhaps a possibility is the color elevation is masking the two elements (roof, dimension), rather than the PDF only showing on the layout.. You could check by going to the elevation view in plan and trying to print, with the "Print in color" unchecked Link to comment Share on other sites More sharing options...
RL-inc Posted February 17, 2024 Author Share Posted February 17, 2024 Thanks Jason- The issue is the pdf view is showing through the CA items once it is sent to layout - In .plan with color toggled off the roof still blocks out the pdf line behind- which is te desired view in Layout Link to comment Share on other sites More sharing options...
SHCanada2 Posted February 17, 2024 Share Posted February 17, 2024 and the dimension question: Are you saying the dimension number itself is in the PDF, but not the dimension line? Why not just put the PDF on its own layer and turn off the layer, or are you looking to show both, but dont like that the B&W layout shows through? If so, why not sent to layout in colour? If you are trying to mask some things in the PDF but not others, the other way to do it would be to put white boxes in your elevation to mask out what you do not want. What I do in cases where I want to use the PDF as an elevation plus some parts of an elevation I have built in CA, I will use the masking boxes plus I will convert the elevation to CAD detail, and then remove anything I do not want from the CAD detail and then copy it back onto the a CAD detail where I have the PDF sitting. And then I align it. But before deleting lines from the CAD detail, I typically double check the scale matches the house on the PDF. For instance I do this when I just want to add a window or Door to a house and I have the existing plans, if the existing plans(rooflines, details) are complex. I did it also once to convert a balcony to a closed in balcony with windows. I find it is a tradeoff in hoping it is less time than redrawing the house. For instance to add a new door, I will draw a house in CA with the correct outside dimensions and add the door. I will import the PDF into a CAD detail. Size the PDF to scale. I will then create a white box where the door will go and put on the PDF in my CAD detail. This will blank out any siding lines. I then Create a CAD detail from view of the elevation. And then copy it over including the exterior line that is the width of the house (usually one below the door). I will then align to that line. Then delete that line, leaving only the door and its trim. In your case, you may be able to just add the white boxes with the correct drawing group to mask what you do not want to see. The advantage of doing a CAD detail from view, is all the lines will be on one layer Link to comment Share on other sites More sharing options...
RL-inc Posted February 17, 2024 Author Share Posted February 17, 2024 Thanks Jason- I did give masking boxes a try, but only halfheartedly- I will take another run at it with an eye to your notes above and see if I get anywhere. much appreciated. Link to comment Share on other sites More sharing options...
