Ed_Orum Posted February 5, 2024 Share Posted February 5, 2024 I want to set plan defaults for a first floor ceiling height of 97-1/8" using a 2nd floor joist of 9-1/2" and a 3/4" sub-floor. The problem is the 2nd floor framing default is factory set at 12-5/8" (3/4" sub-floor and and 11-7/8" joist?) How do I change that? In the Stair dialog box, the total rise is set at 121-1/2", and it should be, sub-floor to sub-floor 107-3/8". How do I set the values to reflect the desired plan conditions? Thanks in advance. Lane Link to comment Share on other sites More sharing options...
Jambruins Posted February 5, 2024 Share Posted February 5, 2024 I believe what you are looking for is under default settings - floors and rooms - floor levels - 2nd floor - floor structure on the bottom of the dialog box 1 Link to comment Share on other sites More sharing options...
SNestor Posted February 6, 2024 Share Posted February 6, 2024 When you built the 2nd floor a dialogue popped up...where you can specify what you want. If you just clicked through and accepted the defaults...Chief just copied your "floor platform" defaults. - Open defaults and go to "Floors and Rooms>Floor Levels>2nd Floor...change the floor structure. Don't make structure changes in your plan in the individual rooms on the 2nd floor. Once you do this it defeats using "defaults". Link to comment Share on other sites More sharing options...
Ed_Orum Posted February 8, 2024 Author Share Posted February 8, 2024 Thanks! Link to comment Share on other sites More sharing options...
