Roof Marker and Text Size
stevenyhof
Go to solution Solved by SNestor,
  • Solution
Change the text style in the "roof label" layer.  I'm guessing but you probably annotated your roof plan at 1/4" and sent to layout at 1/8". You need to make the roof label text 2X (or thereabouts) larger than the 1/4" text style.
Just sent you a video...
