LightHouse_Doug Posted January 24, 2024 Share Posted January 24, 2024 Hi, I'm having trouble with the angular dimension tool. Trying to dimension two floor beams (see attached pic). The 90 degrees is correct, but why is it not snapping to the edge of the beam? My locate objects settings are also attached, and are set to locate the sides of framing. They are steel I beams, not that that should affect anything... Thanks. Link to comment Share on other sites More sharing options...
LightHouse_Doug Posted January 24, 2024 Author Share Posted January 24, 2024 Yes, X12. If I edit area and copy it to a new plan, won't that plan have all different settings? The plan I have the question about is an old plan that does not have all my current defaults etc. set. I can't seem to get the file small enough to attach here, even zipped. Link to comment Share on other sites More sharing options...
LightHouse_Doug Posted January 24, 2024 Author Share Posted January 24, 2024 Thanks, here it is. 8-15-23COPY.zipFetching info... Link to comment Share on other sites More sharing options...
TeaTime Posted January 24, 2024 Share Posted January 24, 2024 Well, for what it's worth, it looks like you already have a dimension there working how you want it to, on the Dimensions, Framing - Floor layer. Link to comment Share on other sites More sharing options...
LightHouse_Doug Posted January 24, 2024 Author Share Posted January 24, 2024 On 1/24/2024 at 6:41 PM, TeaTime said: Well, for what it's worth, it looks like you already have a dimension there working how you want it to, on the Dimensions, Framing - Floor layer. Expand Thanks, but the problem is that I'm trying to create a new saved plan view for structural steel that doesn't have all the floor framing dimensions on it. Link to comment Share on other sites More sharing options...
Solution TeaTime Posted January 24, 2024 Solution Share Posted January 24, 2024 Yeah. I totally get that. Interesting issue I can't say I've encountered before. I pulled your Beams away and the original Framing dimension followed it like I'd expect, but when drawing new angular dimensions I see two things happening: 1) I can still draw a dimension to the "center" of where the beam WAS - which appears to be the railing above, even though it's not displayed AND the dimension defaults are set not to even locate walls. and 2) as long as they're away from those hidden railings, a new angular dimension does attach to the sides as expected. Kind of a pain but you can pull those beams out, dimension them, them center-align them back into position. Also, are you aware that those railings on Floor 1 that these dimensions are snapping to are uh, for lack of a better term, subterranean? Link to comment Share on other sites More sharing options...
LightHouse_Doug Posted January 24, 2024 Author Share Posted January 24, 2024 On 1/24/2024 at 6:57 PM, TeaTime said: Yeah. I totally get that. Interesting issue I can't say I've encountered before. I pulled your Beams away and the original Framing dimension followed it like I'd expect, but when drawing new angular dimensions I see two things happening: 1) I can still draw a dimension to the "center" of where the beam WAS - which appears to be the railing above, even though it's not displayed AND the dimension defaults are set not to even locate walls. and 2) as long as they're away from those hidden railings, a new angular dimension does attach to the sides as expected. Kind of a pain but you can pull those beams out, dimension them, them center-align them back into position. Also, are you aware that those railings on Floor 1 that these dimensions are snapping to are uh, for lack of a better term, subterranean? Expand Ha, thanks for catching that. This model is quite messed up from lots of changes that I haven't had time to properly fix. Deleting that railing seemed to fix the issue. The strange thing is that railings are turned off in that layer set... Link to comment Share on other sites More sharing options...
