CourtneyK Posted January 19, 2024 Share Posted January 19, 2024 Thank you for your time... I am trying to make a shed roof that is16'-6" at it's tallest and slops down to 9'. Off of the back at the bottom of the 9' there is an area I want to be at 9' with an overhang area for a carport. In the picture I need a basically flat, slightly sloped, roof from the end of the roof already pictured to 4' over the room and carport area. I also need to know how to make the walls the correct height at both ends of the slope. I appreciate the help. Link to comment Share on other sites More sharing options...
ACADuser Posted January 19, 2024 Share Posted January 19, 2024 Manually add a roof plane at the rear wall. Update slope in the DBX 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 20, 2024 Share Posted January 20, 2024 DJP 1 Link to comment Share on other sites More sharing options...
CourtneyK Posted January 22, 2024 Author Share Posted January 22, 2024 Thank you Mr. Potter! That video was perfect. I got it all figured out and learned a few things. I reallt appreciate you making that for me. I don't know if my Chief is having a glitch or what but the only problem I had was getting the post on the car port to disappear. I apologize for not being more clear in my description, you were correct in you assumptions Link to comment Share on other sites More sharing options...
CourtneyK Posted January 22, 2024 Author Share Posted January 22, 2024 What if I don't want an attic area and want the ceiling to be open? How do I remove that area? Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 23, 2024 Share Posted January 23, 2024 In each Room Specification Dialog Box - Structure Tab - Ceiling over this room, you "uncheck" the ceiling and that setting for each room it is checked, will take away the flat ceiling and the underside of the roof above then defines the ceiling or common rafter vaulted ceiling. DJP Link to comment Share on other sites More sharing options...
