Hodgin Posted December 29, 2023 Share Posted December 29, 2023 Hello all, Home Designer Pro is new to me and so I am starting out with an easy rectangular garage (26'x28'). The footings are 16" wide and 8" tall and 8" CMU stem wall. I am interested in putting insulation under the 4" slab. How do I add this insulation to show in a drawing? Link to comment Share on other sites More sharing options...
rgardner Posted December 29, 2023 Share Posted December 29, 2023 On 12/29/2023 at 5:06 PM, Hodgin said: Hello all, Home Designer Pro is new to me and so I am starting out with an easy rectangular garage (26'x28'). The footings are 16" wide and 8" tall and 8" CMU stem wall. I am interested in putting insulation under the 4" slab. How do I add this insulation to show in a drawing? Expand Not positibve you can do this in HDP as this is the forum for Chief Architect Premier. But look to see if in your room DBX in the general panel under floor structure if you can add more than just the 4" of concrete floor to the structure and add the 1" or 2" Rigid Insulation under the concrete layer. Link to comment Share on other sites More sharing options...
Garybills Posted December 30, 2023 Share Posted December 30, 2023 On 12/29/2023 at 5:06 PM, Hodgin said: Hello all, Home Designer Pro is new to me and so I am starting out with an easy rectangular garage (26'x28'). The footings are 16" wide and 8" tall and 8" CMU stem wall. I am interested in putting insulation under the 4" slab. How do I add this insulation to show in a drawing? Expand In HDP you can't add layers to the floor structure, but you can make a separate slab and change the material to Insulation and set the elevation below the garage slab. 1 1 Link to comment Share on other sites More sharing options...
