Beam with mitered edges
AlexDiversified
make it out of (3) solids and then use the Union Tool to merge them together.... and then make it into a Symbol for Future use... (set stretch Planes so the 3" part is always 3")
ie (2) pcs 4x4 square for the ends  and the middle part filleted at 3/4" rad. 90" long for a 96" / 8' Beam
31 minutes ago, AlexDiversified said:
This is basically what I want but it is a pre made object so when I go to turn it to 45* it starts getting all weird. Its labeled item P1
Ok, that is not a a 3/4" Round Over , I thought you meant something like this
image.thumb.png.b57ef4f12c2d9e2994709163373d1596.png  or  image.thumb.png.2721402589a7408bbd0d11bbcd7ccf4e.png
That is a Newel Post (P1) I think and to keep that Chamfer/routed edge you would need stretch planes but I don't think Chief Allows Stretch Planes in Rotated objects, in which case it will stretch out the "detail" and it won't look good.
