material adjuster
decorators3
Hi
I've just installed CA 15 - ( which I  am trying to get used to ) When I try to use the "adjust material definition"  to change scale or color - this is the message I get and then I am booted out of CA and have to open and go back in again.
any suggestions welcome
Thanks
Levina
If you went from X11 to X15, there are going to be a lot of differences.  One of the big ones is that X15 is using a completely different rendering engine for all of the camera views.
This looks like a problem with your video card or driver.  Check out this tech article for more info:
https://www.chiefarchitect.com/support/article/KB-00106/troubleshooting-3d-camera-view-display-problems-in-chief-architect.html
If that doesn't help, call tech support.
