Ed_Orum Posted November 9, 2023 Share Posted November 9, 2023 I use a rectangular polyline to outline the notes and diagrams I send to layout. When they arrive in the layout, some of the polyline outlines are invisible. If I click on the layout box border and extend it a little past the polyline, the polyline will display. This does not happen with all of the polylines, but a few on each layout sheet. Is there a setting to offset the layout box border from the item being sent to the layout? Thanks, Lane Link to comment Share on other sites More sharing options...
DBCooper Posted November 9, 2023 Share Posted November 9, 2023 There is no way I know of to specify an offset. I did notice that if I took a blank floor plan and just drew a normal poly and sent the view to layout that the program automatically created a slight offset for me. See picture below. I also noticed that it did this if I did the same thing in a cad detail. Not really sure why this isn't working the same for you. You might want to post a plan or report this to tech support. I suppose if all else fails, you could always create your own "offset" by doing a concentric copy of the poly and then setting the line style to "invisible". It should still be used for sizing the layout box but it won't actually display. Link to comment Share on other sites More sharing options...
Ed_Orum Posted November 20, 2023 Author Share Posted November 20, 2023 Yes, I clicked on the layout boxes and pulled out the borders. They overlap, but since they do not show it works. Link to comment Share on other sites More sharing options...
