Split Level Fun Times
JKEdmo
Go to solution Solved by glennw,
Hi,
Working on a split level and have 2 questions / problems:
1)  I can't seem to get an attic room to form below the uppermost roof (shown below with "?" at the left).  I have one working for the lower roof (shown with check mark on the right).
2) I often get these exterior wall blips on these split levels.  Can I get these to fix by learning a better technique or is it something I need to live with and manually adjust?  I'm guessing Chief is having a tough time resolving the wall cleanup with the level offset...
Plan attached.
Thanks again!
Jim
CARTWRIGHT - AS-BUILTS.zip
  • Solution
You can't build rooms on an Attic floor.
You need to create another floor to build rooms.
I think the errant walls showing through is caused by the wall definitions.
Check your wall definitions - particularly the Main Layer/Exterior Layer settings.
