Custom Object Field Format
KristjanM
I have a number of slabs from which I draw data. I have two custom object fields which have a macro definition. The area column of the schedule provides a total. The custom object fields do not even though they are using the same area number (a formatted version). This would lead me to think that a custom object field cannot be a number (float or integer) but rather is defined as a string. Correct? Can I get a total from a custom object field? Do I need to convert the custom object string to a float?
While we're waiting for the macro whizzes to show up, I think the issue is that formatted values can only be stored as a string. I don't know that custom fields have a limitation on how they're stored.
currently only have the ability to total specific columns to include
You would need to find another method to populate totals. You could do this with a totals object that reports to schedule with its own custom field which does the total calcs for you through a macro that you script. Keeping in mind it would have its own column and row so may not be formatted the way you want:
"currently only have the ability to total specific columns to include"
Not sure what this means. I only see a check box for "Display Totals Row". No option regarding columns. Of course my wife says I'm blind on occasion, so I might have missed something.
bold indicates a searchable term or phrase in the help files. There are only certain built in columns to include within schedules that have the ability to report values to a totals row. Your custom field will not be able to report to a totals row
