DH7777 Posted September 14, 2023 Share Posted September 14, 2023 I need to make the bird box on the right the same size as the left. I know how to auto roof return but it does both at the same time. I need only one side to be extended. Any help would be great Link to comment Share on other sites More sharing options...
TeaTime Posted September 14, 2023 Share Posted September 14, 2023 Under the Boxed Eaves options in the roof plane spec there's a Length you can play with - gotta uncheck Default to Overhang, but this can be used to custom set the box depth past the wall. Link to comment Share on other sites More sharing options...
DH7777 Posted September 14, 2023 Author Share Posted September 14, 2023 36 minutes ago, TeaTime said: Under the Boxed Eaves options in the roof plane spec there's a Length you can play with - gotta uncheck Default to Overhang, but this can be used to custom set the box depth past the wall. THANK YOU! That was it 1 Link to comment Share on other sites More sharing options...
