Macro Coding Template
Joe_Carrick
Here's the Template I use for all my macros.  It provides for error trapping and an explanation of the code.
I hate to have a macro fail with #evaluation error# so I trap errors and return an explanation of the error.
I also liberally place comments in the script so I know what each section is supposed to do.
# YODA'S MACROS - X15 CERTIFIED ON
11-25-2022
#  Copywrite By Joseph P. Carrick
# Macro Name & Description
#  <Name>
#  <Description>
# Set Context and initialize result.
# Make valid for Referenced or Owner Object
referenced ? obj= referenced : obj=owner
result = ""
# Trap errors and provide an explanation
#   begin
/ rescue / end    &   if / elsif / else / end
# sequences can be nested any number of
# levels as needed.
begin
  # Conditional processing where an error
  # might occur.  This code must define the
  # value for result.
  result = <ruby code using object NVPs>
rescue
  # explanation of error
  result = <Error occured because .....>
    -or-
  result = default value (what you want to use as a default)
end
# Display result
result
Here's the Notepad++ "rb" file for editing with Ruby Language formatting.
MacroTemplate.rb
  • Like 5
  • Upvote 2
  • 3 months later...
  • 1 month later...
Joe,
I've tried to DM you a few times about purchasing some macros if you still have them available for sale. One specifically would be a macro for room floor elevation in feet for plan view (not inches as Chief provides it). I suck at ruby scripting so I would be interested in what else you have available for macros for sale.
Thanks.
4 hours ago, Seacoast said:
Joe,
Thanks.
Hi Ron,
I've been very busy and apologize for not answering PM's.
Do you want it for actual elevation?  ie: Sea Level or just relative to Floor 1
I have macros that work in decimal feet as well as in ft_in.
-Joe
Hi Joe,
Thank you for your response. No worries, I can relate to being very busy. I was looking for relative to floor 1 in feet and inches.
Do you have a list of macros available with prices? You can send me a PM if you would like. Thank you
