GParker Posted September 5, 2023 Share Posted September 5, 2023 So I made a newel post with cove moldings under and over , and the molding gaps and the lower disappears when I place in the project I am working on. Any help ? Link to comment Share on other sites More sharing options...
TeaTime Posted September 5, 2023 Share Posted September 5, 2023 If I were to throw a guess at the wall, I'll bet those moldings aren't dropping, but rather the rest of the post is raising. Moldings follow absolute heights while millwork objects follow the finished floor height, so when its placed into a room it's jumping up some in order to rest on the floor. You could check the post's Elevation Reference and set it to Absolute, but I think you'll have an overall better time if you select all of the components of this post and convert it all into a symbol so that it'll be a single item. 1 Link to comment Share on other sites More sharing options...
Solution VHampton Posted September 5, 2023 Solution Share Posted September 5, 2023 How is that object (custom newel) being saved? If it's all blocked (as an architectural block)... Covert it to a symbol - then change the definition of the newels on the stair. That secondary crown under the newel cap should stay in place. Edit: Mr. T's post arrived about 30 seconds before mine. Symbol is the solution. 1 Link to comment Share on other sites More sharing options...
TeaTime Posted September 5, 2023 Share Posted September 5, 2023 8 minutes ago, VHampton said: Edit: Mr. T's post arrived about 30 seconds before mine. Symbol is the solution. I pity the fool who types too slow! 1 2 Link to comment Share on other sites More sharing options...
VHampton Posted September 5, 2023 Share Posted September 5, 2023 Bazinga. You got a green arrow for that one. Link to comment Share on other sites More sharing options...
