Notes in X15, did the behaviour change
ACADuser
I  created a note & schedule like I normally do.
Then to add a new note as before I copied the existing note & edit the text in the note dbx.
This would create a new note before BUT now it alters the previous note to match & does not create a new note.
Did the procedure change or have I got a setting off?
Strange. I don't think there's any reason that should happen. Each Note is a separate thing with its own text.
The only way I know to change two notes at once is to either select them together and open them both, or by using Open Row Objects from the schedule.
