HumbleChief Posted August 10, 2023 Share Posted August 10, 2023 Not sure this should be called a tutorial but here's a technique that can be used to set up a Layout File to handle a simple home remodel. There is a down side to using 2 different template plans in Layout and that is when updating a template plan it require 2 template plans be updated. Not a big deal since the template plan only needs updating occasionally but it needs to be remembered. 1 1 Link to comment Share on other sites More sharing options...
CJordanDesign Posted August 16, 2023 Share Posted August 16, 2023 This was such a great help! Changing the reference file saved a huge amount of time. Thank you for this tip! 1 Link to comment Share on other sites More sharing options...
JKEdmo Posted August 16, 2023 Share Posted August 16, 2023 On 8/10/2023 at 9:59 AM, HumbleChief said: here's a technique that can be used to set up a Layout File Very helpful video! I recently discovered that same layout tool that allows you to repath the .plan files. Up until now -- for about a year -- I had been repathing each layout view manually one by one! Jim 1 Link to comment Share on other sites More sharing options...
