Simple Remodel Layout Setup - Tutorial
HumbleChief
Not sure this should be called a tutorial but here's a technique that can be used to set up a Layout File to handle a simple home remodel. There is a down side to using 2 different template plans in Layout and that is when updating a template plan it require 2 template plans be updated. Not a big deal since the template plan only needs updating occasionally but it needs to be remembered.
Expand
Very helpful video!
I recently discovered that same layout tool that allows you to repath the .plan files.  Up until now -- for about a year -- I had been repathing each layout view manually one by one!
Jim
