Thad58 Posted August 7, 2023 Share Posted August 7, 2023 I have been trying to get a brick band on this house with no luck. I can get it close using a soffit and changing the material but, in the camera, view it does not look the same. I have been using Chief since X3 and it is my first brick house. I can’t believe there is not a tool or a brick band molding for this. Is this something that must be done manually? Link to comment Share on other sites More sharing options...
Chopsaw Posted August 7, 2023 Share Posted August 7, 2023 It appears that you have adjusted the pattern of the material which works in the vector views but does not affect the standard or raster views where the texture is used. There are corresponding Course Brick materials in the core library that should work for you. However you may still need to rotate them. Link to comment Share on other sites More sharing options...
javatom Posted August 7, 2023 Share Posted August 7, 2023 Use a molding polyline instead of a soffit. It will be easier to control. Link to comment Share on other sites More sharing options...
