winterdd Posted July 26, 2023 Share Posted July 26, 2023 Hello my fellow CA's. I got a request today to see if I could not include the sheetrock when I export my floor plans CA files to .dwg. Is this possible? I am always trying to to make the engineer's job a little easier. Link to comment Share on other sites More sharing options...
robdyck Posted July 26, 2023 Share Posted July 26, 2023 2 ways to do this that I can quickly think of...turn on the layer for walls, main layer only. This will also eliminate exterior wall layers from those views. I never show the finish layers in my floor plan views, except when showing larger scale views...1/2" scale or larger. The other way is to manually edit the cad file and then send it (gross). Link to comment Share on other sites More sharing options...
winterdd Posted July 27, 2023 Author Share Posted July 27, 2023 14 hours ago, robdyck said: 2 ways to do this that I can quickly think of...turn on the layer for walls, main layer only. This will also eliminate exterior wall layers from those views. I never show the finish layers in my floor plan views, except when showing larger scale views...1/2" scale or larger. The other way is to manually edit the cad file and then send it (gross). Gross is right.......and thanks, I will defintely look into your suggestion. Link to comment Share on other sites More sharing options...
