SHCanada2 Posted July 22, 2023 Share Posted July 22, 2023 I have a cantilever, but when CA frames it. the Floor truss inside the cantilever extends beyond the cantilever wall, and thus ends up partially off the edge of the outside of the foundation wall It is highlighted in blue 694 Muirfield Cr - fe (4).zip other than deleting it and then causing auto to run off, any other way? Link to comment Share on other sites More sharing options...
Garybills Posted July 22, 2023 Share Posted July 22, 2023 Try marking the little room that was formed between the two walls as unfinished instead of open below. Then rebuild the floor framing, it also draws in the rim joist that was missing. Link to comment Share on other sites More sharing options...
SHCanada2 Posted July 22, 2023 Author Share Posted July 22, 2023 that worked! thanks. ...Although I think CA should be smart enough not to build framing outside of exterior walls... Link to comment Share on other sites More sharing options...
Garybills Posted July 22, 2023 Share Posted July 22, 2023 1 hour ago, SHCanada2 said: that worked! thanks. ...Although I think CA should be smart enough not to build framing outside of exterior walls... It was strange how it built the truss there!!!! I just stumbled into the little room, I was about to give up when I deleted the inside wall in the stairwell and the render changed to a rim joist instead of the floor truss. Link to comment Share on other sites More sharing options...
SHCanada2 Posted July 22, 2023 Author Share Posted July 22, 2023 34 minutes ago, Garybills said: It was strange how it built the truss there!!!! I just stumbled into the little room, I was about to give up when I deleted the inside wall in the stairwell and the render changed to a rim joist instead of the floor truss. in case anyone is wondering why the little room is there. ..below is a 8" concrete foundation, so the wall had to be offset 1 Link to comment Share on other sites More sharing options...
