DefinedDesign Posted June 27, 2023 Share Posted June 27, 2023 Came across this article: https://www.chiefarchitect.com/support/article/KB-00805/editing-2d-cad-blocks-assigned-to-3d-symbols.html but there are no instructions for the need I have. I want to take the quadraplex 2D CAD and add the GFCI letters to it. After I explode the CAD block as instructed, if I de-select it, it disappears. If I open the dialog box as instructed I don't have the options for text. I realize I might be misunderstanding, so I thought I would ask if anyone knows of a video tutorial on how to do this in X12. Thanks in advance! Link to comment Share on other sites More sharing options...
Solution DefinedDesign Posted June 27, 2023 Author Solution Share Posted June 27, 2023 This is what I did to get what I needed: Add a Quadraplex Outlet and a GFCI Outlet to Working Plan View: >Select the Quadraplex Outlet in the plan and Select CAD> CAD Block Management from the menu, and in the list of CAD blocks, find the Quadraplex CAD block and select it. >With the CAD block selected, click the Insert button, then click somewhere in the drawing area to place a copy of the selected CAD block. >Select the newly placed CAD Block click the Explode CAD Block edit button. >Select the GFCI Outlet in the plan and Select CAD> CAD Block Management from the menu, and in the list of CAD blocks, find the GFCI CAD block and select it. >With the CAD block selected, click the Insert button, then click somewhere in the drawing area to place a copy of the selected CAD block. >Select the newly placed CAD Block click the Explode CAD Block edit button. >Now that both CAD Blocks are exploded move the GFCI letters over to the Quadraplex symbol. Delete the rest of the GFCI symbol. >Using the Select Objects tool, left-click and drag a marquee around the newly created Quadraplex GFCI symbol. >With the objects selected, click the Make CAD Block edit button to block the objects back together. >Select the block and click the Open Object edit button. >On the General panel of the CAD Block Specification dialog that displays, type a short, descriptive name for the CAD block, then click OK. >To use this newly created CAD block for the electrical symbol, select the Quadraplex symbol placed in the plan in the first step above, then click the Open Symbol edit button. >On the 2D Block panel of the Symbol Specification dialog, select the block created in the previous step from the list of Available CAD Blocks, then click OK. >Add the symbol with its customized 2D block to the User Catalog folder in the Library Browser by selecting the symbol and clicking the Add to Library edit tool, right click on the symbol in the User Catalog folder and name to Quadraplex GFCI. Hope this helps anyone who needs it. Please comment if there is a simpler way to achieve this, always willing to learn! Link to comment Share on other sites More sharing options...
DBCooper Posted June 27, 2023 Share Posted June 27, 2023 Yeah, it's easier in X13 and newer because you can just use the "edit cad block" tool: https://www.chiefarchitect.com/support/article/KB-00805/editing-2d-cad-blocks-assigned-to-3d-symbols.html#X13 Link to comment Share on other sites More sharing options...
DefinedDesign Posted June 27, 2023 Author Share Posted June 27, 2023 On 6/27/2023 at 10:39 PM, DBCooper said: it's easier in X13 and newer because you can just use the "edit cad block" tool Expand Curios, does this allow the user to add text if there was no text in the original symbol? Link to comment Share on other sites More sharing options...
DBCooper Posted June 27, 2023 Share Posted June 27, 2023 It's just like any other cad block in that you can add lines, text, rich text, dimensions, filled polylines, or whatever. 1 Link to comment Share on other sites More sharing options...
