Drew-PRH Posted June 22, 2023 Share Posted June 22, 2023 Good day, I am needing to place a 2x4 partial wall (pony wall) over a portion of the 2x6 Exterior Wall. For Example: The 2x4 Pony Wall will join the 2x6 Exterior wall - stud to stud. As seen in the images, the Pony Wall will be 64" high, and have a niche within that wall. Tile will not apply properly to the 2x6 exterior portion on the interior side. So I am having some issues with creating the proper application so all walls looks and flow together. Thanks for the insight to build this proper - Drew Link to comment Share on other sites More sharing options...
DefinedDesign Posted June 23, 2023 Share Posted June 23, 2023 I wonder if breaking the exterior wall at the width of your half-wall and then converting the exterior into a pony wall and on the upper wall dialog add a drywall layer and a tile layer. Nice design! 1 Link to comment Share on other sites More sharing options...
robdyck Posted June 24, 2023 Share Posted June 24, 2023 You need to make the half wall a 'furred wall' in the Structure tab. However, there will still be some drywall missing, but on the ends instead of the back. This can be corrected by editing the wall layer intersections in plan view. Select the side walls, click the Edit Wall Layer Intersections tool and extend the drywall layer to the back wall. In the view below, I have simply 'painted' the drywall material to tile for the Shower room, so it's not 100% accurate but the principle applies. I would add backsplashes once the design was finalized. Link to comment Share on other sites More sharing options...
Drew-PRH Posted July 31, 2023 Author Share Posted July 31, 2023 Thank you Robert, Been busy with other items and not sure how I missed your info - Thank You. I'll revisit those areas and implement your suggestion, as it looks like it worked for you just fine. And I'll apply tile as well to the upper portion of Exterior Wall with a Window inserted. Thanks again - Drew 1 Link to comment Share on other sites More sharing options...
robdyck Posted August 2, 2023 Share Posted August 2, 2023 @Drew-PRH Glad to hear you have your issue taken care of. If you get the chance, please check the the post that helped you as solution which will help others! Thx. And maybe post an image of your result after you've implemented the fix. It's helpful and interesting to others to see the before and after! Link to comment Share on other sites More sharing options...
