How to draw vertical rope light X15
HannahMcNee
  • 1 month later...
Hmmm not sure if there is an actual way to do that, but I've done LED strip lighting behind a recessed TV. I couldn't find a direct option to do this so i just created / duplicated the LED Texture,  created a custom molding line where i needed it, then painted to be the luminous LED texture. While you don't have as much light control over it, it works nicely in a pinch.
That's good one, Reenee.  Pardon my nick for my favorite teacher.  Too bad we can't copy distribute on path those light sources.  Or can we?  Maybe not vertical.
One thing I really like about your toots, is the caption pic vid of you, as you speak and watch and glance at the keyboard or whatever space age device (joystick?) you are using.  The effect is like being in a classroom.
The remarks about light bleed are gold.
