HannahMcNee Posted June 19, 2023 Share Posted June 19, 2023 Does anyone know how to draw or rotate a rope light to be vertical rather than the standard horizontal? Link to comment Share on other sites More sharing options...
TCB_BdnMY Posted August 14, 2023 Share Posted August 14, 2023 Hmmm not sure if there is an actual way to do that, but I've done LED strip lighting behind a recessed TV. I couldn't find a direct option to do this so i just created / duplicated the LED Texture, created a custom molding line where i needed it, then painted to be the luminous LED texture. While you don't have as much light control over it, it works nicely in a pinch. Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 14, 2023 Share Posted August 14, 2023 On 6/19/2023 at 3:57 PM, HannahMcNee said: Does anyone know how to draw or rotate a rope light to be vertical rather than the standard horizontal? Just did a video for this posted here: 2 Link to comment Share on other sites More sharing options...
GeneDavis Posted August 22, 2023 Share Posted August 22, 2023 That's good one, Reenee. Pardon my nick for my favorite teacher. Too bad we can't copy distribute on path those light sources. Or can we? Maybe not vertical. One thing I really like about your toots, is the caption pic vid of you, as you speak and watch and glance at the keyboard or whatever space age device (joystick?) you are using. The effect is like being in a classroom. The remarks about light bleed are gold. 1 Link to comment Share on other sites More sharing options...
