Building a base cabinet with a sloped or angled top with conforming counter
DaveDi
Go to solution Solved by joey_martin,
12 minutes ago, DaveDi said:
Hello,
I am trying to design a base cabinet with an angled top and conforming counter. Can anyone direct me to an instructional video? I searched angled cabinets and tops and didn't find much.
Thank you in advance for any assistance.
-D
it can be done..does it need to be a cabinet? The solution is complicated
  • Solution
Nahh....don't over think it.
Just like you did on the left side. Make the base cabinet on the right JUST the 2 drawers, add a custom countertop that extends over all 3 base cabs and ends where you need it to end on that angle. They fill in the back with the custom backslash tool or a material region to match the cabs. The light angle piece can be drawn as a solid and stretched in place.
you quoted me by the way..solution is complicated if you wanted it as a cabinet..no backsplashes
Worked perfectly. Thanks
