capitaldesigns Posted May 17, 2023 Share Posted May 17, 2023 I am working on a covered patio with arched opening. I following ds hall video titled arches and corner windows showing how to build these arches. I am encountering two problems that I do not know how to resolve. I can not get rid of a piece of a wall that shows up at one of the corners of the patio. Does anyone know how to get rid of this wall ? The other problem is the client wants the arch of the patio to end over an existing door leading into the house. With the arch ending over the door the door gets covered up with stucco. Is there a way to prevent the door from being covered up with stucco ? I've included the plan file and a screen shoot of a perspective view of the back of the patio. I marked up the two areas I am having the problems. Thank You, Mike 1846846860_BruceJones-Design1.plan Link to comment Share on other sites More sharing options...
TeaTime Posted May 17, 2023 Share Posted May 17, 2023 Ponywalls with lower wall type Room Divider, Height off Floor 101" to match the bottom of your passthroughs. That'll remove all lower wall stuffs, though it trades two issues for another: Edit Wall Layer Intersections to pull the stucco through that wall intersection: thusly: voila Link to comment Share on other sites More sharing options...
