Hiding red lines around exterior light fixtures
DeWaltDad2020
58 minutes ago, rlackore said:
Check the layerset - it's possible that the fixtures are on a layer with a color set to red; if so, change the layer color.
1420572791_ScreenShot05-08-23at09_17AM.thumb.JPG.4a3300364409f21c960202cfa1d86044.JPG
Exactly this.  Just a note based on the question type that you may or may not be aware of.  There is a different layer set associated with your plan view vs. your 3d view. Make sure you make the change in the 3d view so as to not affect your MEP plan.
