Roofs & Multi Pitch Intersections - How to add Exterior Wall that Roof Intersects
wazzubrad
Go to solution Solved by TeaTime,
Guys,
I have ran into this scenario a few times, where Roof planes that share the same ridge but are two different pitches, and I can't seem to get the Exterior Wall that fills the area between the two pitches to fill in correctly. I pasted a photo below as well as attached the plan file. What is best practice on how to get this wall added?
Cabin.zip
  • Solution
Manually.
On Floor 2, break the wall at that intersection and use the diamond to drag a new wall across the house.
image.png.8d3c79118afdd59a45d6d265bceb4d6e.png   image.thumb.png.00039d3167b93a9e4d0d97de5ff51826.png
(less if they're not sharing a ridge)
Open new wall, Roof panel, "Roof Cuts Wall at Bottom"
Changes wall shape from
image.png.f8759447e8c63f559dc40eee7924929e.png to image.png.08cd4b3b185ea730f8a998a0590306d2.png
(You shouldn't need to but I had to manually pull the right roof plane under the wall -- it's supposed to happen automatically but it can be finicky sometimes.)
