LCDesign Posted May 3, 2023 Share Posted May 3, 2023 Link to comment Share on other sites More sharing options...
LCDesign Posted May 3, 2023 Author Share Posted May 3, 2023 I am trying to modify the value for the Label component. See the highlighted blue box. I cannot edit this. I am using X15. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 3, 2023 Share Posted May 3, 2023 Next time post your question in the General Q&A section. This forum is for sharing actual symbol and content resources. To answer your question though, double click in the Formula field. That field on the right is just the results of what gets entered on the left. Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 3, 2023 Share Posted May 3, 2023 38 minutes ago, LCDesign said: I am trying to modify the value for the Label component. See the highlighted blue box. I cannot edit this. I am using X15. Pasting this response which was to your same post on FB I would ask why you arent changing the label in the label panel? To answer your specific question, the formula panel is where you could change the label in this case. But this is only changing the label for a material list, not for the plan view or schedules Link to comment Share on other sites More sharing options...
