Edit a component
LCDesign
Next time post your question in the General Q&A section.  This forum is for sharing actual symbol and content resources.  To answer your question though, double click in the Formula field.  That field on the right is just the results of what gets entered on the left.
38 minutes ago, LCDesign said:
I am trying to modify the value for the Label component.  See the highlighted blue box.  I cannot edit this.  I am using X15.
Pasting this response which was to your same post on FB
I would ask why you arent changing the label in the label panel?
To answer your specific question, the formula panel is where you could change the label in this case. But this is only changing the label for a material list, not for the plan view or schedules
