Temporary Dimension snap location
mbblakesley
This has happened to me before but I can't remember the solution.
My temporary dimensions are snapping to the outside of the door & window casing, as well as the outside surface of the wall. How do I reset it to be to the framing??
I can't find anything in the temporary dimension defaults
Thanks!
To expand on what was posted above, temporary dimensions follow the settings in whatever Dimension Default is Active at the time. You can switch the active dimension default for various purposes, which you probably did inadvertently.
I have added the Active Dimension Defaults Control drop-down tool to my toolbar so I can change out the settings if needed- usually temporarily.
